Divide surface and rotate objects individually
Hello!
I am trying to divide the surface and to rotate rectangles with random components. However, it seems like the objects on each row turn the same degree. I noticed that it does the same when I apply the random list to the height of the object. I have tried different ways, but it feels like I am stuck.
Thank you very much!
divide_rotate.gh (14.2 KB)
divide_rotate.gh (12.6 KB)
Thank you so much! :pray: I have not used Clean Tree before. I should learn how it works.
Hi Taekyeom,
While Aquintana’s method works, I’ve attached my solutions as well. See if this helps.
Cheers!
Kaushik LS
Chennai, IN
FILE: 2020.10.27 - divide_rotate - re2.gh (14.4 KB),
