Divide flat list into Branches of different lengths using Replace Path component
hi. test.gh (2.9 MB)
I am trying to construct a new data tree using the branch organization of another tree’s branch lengths. Both tree when flattened have the same amount of items and I am using the ‘Replace Path’s’ component.
Please see the image and attached GH file. Any help would be appreciated!
Graft your data and then have 2 flat lists going into the path inputs. All lengths must match.
Thanks for the reply, your solution didn’t use the list of breps as an input, but rather used the output of the dispatch node.
My goal was to ‘divide’ a source list (the list of breps) by another data tree’s branch lengths as a pattern. I forgot about ‘partition’. This gave me the result I needed.
I think this may be possible with ‘replace paths’, but is not necessary in this instance it seems. Thank you for the help.
Perhaps the partition list component would help.
