Hi, so im tryin to make this second skin as facade with base using ellipse, but when i loft it, it turns to Open Brep, i want to divide this Brep and put some pattern on it but im strugling because it’s not surface. I hope anyone can help me with this
I didn’t understand what you expect to get exactly, the reason why the Loft component is turning orange is this Null coming from a Move component that has no input Geometry:
by the way, I’d go for a Network Surface, by providing also vertical curves (the following is just a hint to show you the result, but I won’t take those curves from Loft → Brep Edges: I would just generate them earlier in a clean way)
hi, you were right, something was missing and here is the file Facade.gh (17.7 KB)
what i want to do is i want to merge the surfaces so i could put this pattern
You might want to use a different method to generate vertical curves in such a way to have more control on the shape, but this example shows you the result you will get
