Divide closed curve into several closed curve by split lines
Hello. I have the following issue: I need to divide each closed curve, into several smaller closed curves, along existing division lines. Is there any way to do this with less labor?
I think you could make a surface out of your initial closed curve, split it, and retrieve the edges of each slice
Curve.CreateBooleanRegions might work for you. I don’t know if it’s implemented in native Grasshopper components yet, but one can implement it a scripting component if not:
Thank you. I downloaded the grass-file, but I get an error when opening the python script: ā€˜type’ object has no attribute ā€˜CreateBooleanRegions’. Maybe the problem is in the Rhino version? I have 6.
That was my first thought, but I have a lot of branches and elements, so this approach takes a lot of time and I’d like to do without building surfaces so as not to reduce the speed of the script.
Yup, the CreateBooleanRegions method was added in Rhino 7.
Can I get any solution in Rhino6?
3. Attach minimal versions of all the relevant files
Hope dies last (should die first)
BrepFace_SplitWithOffsetCurves_V1.gh (131.8 KB)
Note: RC crv.Offset() Method used is useless (in most complex cases). So sample ā€œsimpleā€ splitters (and cross fingers).
