Hello, i am using DIVA 4 in grasshopper to get the annual daylight data for a geometry but the output doesn’t change. It’s always the same and indipendet from geometry , is there any mistake ?
It’s probably best to ask this on the DIVA forum:
One thing I can spot from looking at your screenshot is that the name you are using has a space. You need to remove spaces in the naming of your files as well any spaces in file path descriptions. Radiance does now allow any spaces.
Or maybe there’s something wrong with the Materials ? I don’t know .
And did you finish it ? Could you describe how did you finish it ? I may have a same question , thank you !
He does not have geometry plugged into the scene objects.
