Any ideas of how to fix this? (pics attached) At some angles I get hidden lines, and then other times it’s fine. making very hard to both model, and show to client. I’ve seen other topics about this from 2014, but I’ve already tried those suggestions.
Erverything is modeled in Rhino except for the feet of the desk. I’m not concerned with those mesh lines) - and disregard those color crvs in the BG
I’ve reset the shaded display to default (except taking out isocurves)
Hello Alan,
Would it be possible to send us the model / its part to reproduce the error? Which Rhino do you use? I believe it’s caused by tolerance, size or distance from the origin.
Thanks for the replies. Here’s the file. I exported to a clean file with just the desk model, and it indeed works ok now.
How can I set Rhino to be able to handle everything I need it to without the very (very, very) inconvenient need to separate my construction crv/geometry from my modeling?
Well, the short answer is you can’t.
Rhino display was designed for objects that generally stayed in the viewport.
It has problems when it is pushed way beyond how it was expected to be used.
I know this has been on the radar for improvement for a long time.
You could make things a lot easier on yourself by using the Layout feature and move borders and titles to separate layouts. Another layout could be used to collect all your symbols.
