Today I noted the following bug (I think it is a bug):
When printing directly from the Viewport to Rhino PDF this is the result I get (when I use my special Display Mode) :
When printing from the Layout to Rhino PDF the same area looks like this (using the same Display Mode in the Detail - same scale 1:50 as well):
It seems that the Layout Detail view does not respect the Gamma setting of the Display Mode when it is used in a Detail.
I think this is a bug. If not - can someone please explain where the output gamma of the Layout Detail can be changed ? Or how this can somehow be fixed (I can desaturate the PDF of course.)
While talking about the Gamma … ![]()
When several Display Modes are used simultaneously to display different parts of a model. How does the Gamma value work then ? Does the Gamma of one Display mode take precedence over the other Display mode? That’s what I think. But does it need to work that way ?
Thanks
/Erik
