Hello all,
Please see systeminfo and attached Rhino file for your reference.
Rhino 8 SR28 2026-2-10 (Rhino 8, 8.28.26041.11001, Git hash:master @ b7874a05a6982d0419fcc4f6009b510b48a09cb3)
License type: Commercial, build 2026-02-10
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 8.0.25
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1060 6GB (NVidia) Memory: 6GB, Driver date: 7-14-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 577.00
Accelerated graphics device with 4 adapter port(s)
Secondary graphics devices.
Intel(R) HD Graphics 630 (Intel) Memory: 1GB, Driver date: 8-28-2025 (M-D-Y).
Integrated graphics device with 3 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-14-2025
Driver Version: 32.0.15.7700
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\Administrator\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\byRhinoGadget\1.4.7\net7.0\byRhinoGadget.rhp “byRhinoGadget” 1.0.0.0
C:\Users\Administrator\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\byRhinoGadget\1.4.10\byRhinoGadgetPlus.rhp “byRhinoGadgetPlus” 0.0.0.0
C:\Users\Administrator\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SwordfishRhino\1.0.11\net8.0\SwordfishRhino.rhp “SwordfishRhino” 1.0.11.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.28.26041.11001
Box.3dm (80.9 KB)
I am currently working on a project that requires objects in the same detail but with different display modes. On this example, I have a blue box and a red box. I have set the display mode for the red box as wireframe, and the blue box as “by view” which is set in technical mode . When I set the display modes, it displays fine (see picture “before closing”). However, after saving the file and opening it again, the red box which is in wireframe mode disappears from the detail, but the 3D model is still in the model space (see “after closing” and “after closing-1”.) I have tried this on a different PC but the problem persists.
The workaround I’ve discovered is that after opening the file, I select the red box, set the display mode to “by view” then set it back to “wireframe”. Now the red box can be seen. Although this might be simple to do, I’m currently working on models with several hundred parts, and may require differing display modes.
I would like to ask if anyone has encountered this before, and what actions have been done to address this issue. Thanks very much.
