Display issues
The original model has meshes, I want to convert those to surfaces and even If I create solids from then there are display issues where lines of selected elements are extremely thick and gets worst when zooming out where it covers the entire screen and nothing else can be seen.
Hi Franscisco,
Please run the SystemInfo command in Rhino and post the results. An example file showing the behavior will be needed as well. Thanks!
Hi Japhy, Please find attached.
Error_model.3dm (2.3 MB)
systeminfo_FC.txt (2.9 KB)
The file looks normal here.
Remote Desktop might be a factor here (unsupported display environment)
Do you have PrintDisplay on or any custom width scaling in the display mode?
  Primary display: Microsoft Remote Display Adapter (Microsoft) Memory: 0MB, Driver date: 6-21-2006 (M-D-Y).
    > Remote Desktop display device with 16 connection(s)
        - Windows Main Display using connection #0
  Primary OpenGL: NVIDIA Quadro K2200 (NVidia) Memory: 4GB, Driver date: 8-1-2016 (M-D-Y). OpenGL Ver: 4.5.0 NVIDIA 369.09
    > Accelerated graphics device with 0 adapter port(s)
        - There are no monitors attached to this device!
PrintDisplay shows off. Not sure about custom width scaling, I just have it in full screen model in the Remote Desktop settings.
Can you update the driver? Note that Remote Desktop is not supported.
