Rhino Display bug?
I used SrfPt command but it only build me a 1degree surface in default.
And I rebuild it to a 3 degree surface, the display won’t work out. It looks like this.
I have already adjusted the display quality to the hightest value.It used to be good this problem just occurred today. Dose anyone came into the same trouble?
Thanks a lot.
Hi Ian- please post a file with the surface, thanks.
display problem.3dm (61.0 KB)
Sorry for my delayed reply,this is the file.
I tried many times ,the problem still exists.
Thanks very much for your attention.
Hi Ian - set a custom meshing for this object (Properties > Custom mesh) - it does not like the current document mesh settings (DocumentProperties > Mesh page) or change those settings. Setting initial grid quads to some number like say 32 will help. I guess the meshing is not being refined because it is a linear surface, if you move one point to make it non-linear, it cleans right up, even with the current document settings.
Thanks a lot.I solved the problem.
Thank you.
