Whenever Rhino crashes and i recover the autosaved file, the display in the shaded and rendered views are changed to like this photo (shaded view) and i cannot get them to go back to the origial display, any ideas what this is?
Hi Julia - it’s very hard to tell what’s going on in that picture.
For starters, could you run the Rhino SystemInfo command and copy-paste the result here?
Thanks,
Rhino 6 SR13 2019-2-27 (Rhino 6, 6.13.19058.371, Git hash:master @ 17cd8b51accbe17dd04b48028f49d5e77a67f17b)
License type: Commercial, build 2019-02-27
License details: Stand-Alone
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: DESKTOP-PVS1RG6
Non-hybrid graphics.
Primary display and OpenGL: Intel® UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 9-25-2019 (M-D-Y). OpenGL Ver: 4.6.0 - Build 26.20.100.7262
Secondary graphics devices.
NVIDIA GeForce GTX 1650 (NVidia) Memory: 4GB, Driver date: 3-18-2019 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 26.20.100.7262
Driver Date: 9-25-2019
Driver Version: 26.20.100.7262
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.13.19058.371
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
Thanks, Julia.
A few things:
The current version is 6.25 - please update to that version.
You have 2 GPU’s in that machine. The Intel 630 is set to be the one that is drawing the viewports in Rhino. Your GeForce GTX 1650 is a lot more powerful and you should get this one to do the work.
If you have an external monitor, make sure that it’s plugged into the connector of the GTX card. You might also have to check settings in the NVIDIA Control Panel that you can open by right-clicking on your desktop.
Please try these things first and let us know if that helped.
That sounds like an external monitor is connected to the Intel GPU and not the NVIDIA GPU.
Im working from a Dell XPS laptop, so can you help me in trying to connect it to the NVIDIA GPU instead of the Intel one?
Are you using an external monitor?
nope, but thank youuu i solved the issue and had my laptop working with the NVIDIA GPU, thank you so much!
