Working on a command for a plug-in and for logic further down the line I need to figure out whether the user selected a specific surface through sub-object selection (Ctrl+Shift while clicking) or regular clicking on the Brep. Is there any way to do this or am I forced to create separate commands for the different ways of selecting?
I don’t have direct experience, but this looks useful
Thanks! I’ll give this a go and report back
Hmno, I might be doing something wrong. But it returns a True boolean both when I Ctrl+Shift click or regular click on the object.
How do you currently perform the object selection?
This script seems to work once you cancel out the filter:
import Rhino
import scriptcontext
def test_get_brep_face():
go = Rhino.Input.Custom.GetObject()
go.SetCommandPrompt("Select surfaces")
#go.GeometryFilter = Rhino.DocObjects.ObjectType.Surface
go.SubObjectSelect = True
go.GetMultiple(1, 0)
if go.CommandResult()!= Rhino.Commands.Result.Success:
return
for objref in go.Objects():
print(objref.ObjectId)
print(objref.GeometryComponentIndex.ComponentIndexType)
print(objref.GeometryComponentIndex.Index)
if __name__ == "__main__":
Hmm I use Brep as a filter instead of Surface. Could that be the problem?
Stripped down it looks something like this right now:
var go = new GetObject();
go.GeometryFilter = ObjectType.Brep;
go.SubObjectSelect = true;
while (true)
go.GetMultiple(1,0);
if (go.CommandResult() != Result.Success)
return Result.Failure;
break;
I don’t know the rest of your code, but if I try this it still seems to function:
from Rhino.Input.Custom import GetObject
from Rhino.DocObjects import ObjectType
from Rhino.Commands import Result
def go():
go = GetObject()
while (True):
result = go.GetMultiple(1,0)
if (go.CommandResult() != Result.Success):
else:
return go.Object(0).Geometry()
break
print go()
Hi @Gijs, But how does it indicate whether you have selected the Brep using Sub-object selecting (so Ctrl+Shift to select 1 surface of the brep) or regular selecting (just clicking and selecting the whole brep)?
if I run the last script I posted and subselect a face (of a box) I get this as result:
<Rhino.Geometry.BrepFace object at 0x0000000000000088 [Rhino.Geometry.BrepFace]>
now if I run again and select normally I get:
<Rhino.Geometry.Brep object at 0x0000000000000089 [Rhino.Geometry.Brep]>
Sorry, I should have tested this before asking.
Thanks, I think this should get me going!
