In some scenarios, I need users to select only a subset of a surface.
Setting get.SubObjectSelect = true;
when calling the GetObject
method allows this functionality. However, I want to enable direct selection without requiring the user to press the Ctrl key. How can this be achieved? Thank you!
Hi @yangf85, below python example prompts to select surfaces of breps:
import Rhino
go = Rhino.Input.Custom.GetObject()
go.SetCommandPrompt("Select a brep face")
go.SubObjectSelect = True
go.DisablePreSelect()
go.GeometryFilter = Rhino.DocObjects.ObjectType.Surface
go.GetMultiple(1,0)
For single surface selections, it works using RhinoScriptSyntax too eg:
obj_ref = rs.GetObject("Surface", 8, False, False, None, subobjects=True)
_
c.
hi @clement
Thanks for your help. It’s useful.
