Hi Clint - if you start with a blank file and make some dimensions, can you tell what action prompts a new dimstyle to show up? Is it with each new dimension, or by copying them or copy/paste from another file… etc.?
Just getting back to this question, Pascal. I can’t figure out when and where it starts to kick in. When I make a new blank file and make multiple leaders with a certain dim style, I don’t get the problem. If I open a new layout using my template and make dimensions and leaders, I don’t get the problem. I only see the long list when I go to SET DIMENSION STYLE.
I have a regular .3dm file that I use in my own folder to save dim types, layout formats that I like, etc. When I model a boat and am ready for making layouts, I import a layout from this file. Is that the issue?
Hi Clint - that seems possible - but I cannot repeat it , though I may be doing it wrong…
I made a file with a layout and a custom dim style
I imported the layout to my current file.
I started adding dims using the custom dimstyle from the imported layout - so far, the dimstyles are not reproducing.
