Is it possible to create my custom dimension type and style?
Yes. DocumentProperties > Annotations > Dimensions.
(From the top of my head)
Hello wim,
Thanks for answer. It is not completely what I wish to do.
I would like for example to create my dimension style and use it like standard Rhino dimensions.
To add more dimension types.
To draw a dimension style and save it someway
to the interactive block actually like Rhino dimensions are.
I will upload an image to show what I mean.
I’m sorry. I don’t understand what you want. As far as I can tell, what you ask for is possible. You’ll have to spell it out where it is where you get stuck.
I think your problem is that you need to save it to a template to have it available for the next new file.
Open a new blank file.
Create as many dimension styles as you need.
Make any document Property changes you want to see in a new file, e.g. meshes, units, grid etc.
Save that file to someplace you can always access it.
In Rhino Options>Files>Template files point to the file you just customized and make it the template.
Now when you create a new file Rhino it wll have your styles and other optimizations available.
Nick
