I am having trouble with dimension text not fully displayed. I have tried adjusting text settings. How do I fix this? Thanks.
Can you post the result of the Rhino command SystemInfo in an answer here?
There have been a few other reports of this behavior. Please make sure to update both Rhino and Windows. Ref.: Text cut in half in Rhino 6
FYI, our fix was getting latest windows updates. Weird but it worked directly or indirectly
The result is below - thanks. I have Windows 10 and Rhino updated.
Rhino 6 SR3 2018-3-31 (Rhino 6, 6.3.18090.471, Git hash:master @ b32d93f452fce970e96deb46bfc68b075f06b290)
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
GDI Generic (OpenGL ver:1.1.0)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 5-19-2016
Driver Version: 9.17.10.4459
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 2076 MB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18031.1000\5.5\Legacy\Flamingo.Legacy.dll "Flamingo nXt Legacy File Reader "
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
C:\Program Files\Rhino 6\Plug-ins\NamedPositions.rhp “Named Position”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18100.1000\5.5\Flamingo.nXt.rhp “Flamingo nXt 5.5”
Rhino is not finding any GPU at all on your PC. This is most likely not the case. Do you know which GPU is installed? Find the latest drivers for that card and install those.
I have an Intel HD Graphics 3000 and I confirmed that the latest drivers are installed, Intel no longer supports this GPU and the last driver set is from 5/18/2016 (ver. 9.17.10.4459). I do not have an issue with Rhino 4.
Thanks.
