Dimension lines hidden over pictureFrame images
V5
drawing dimensions over raster images created with pictureFrame, the lines between arrows are hidden, until I use BringToFront. means every time I draw a dimension i have to use bring to front.
The rasters are planar on Cplane, the dims are drawn on Cplane.
I dont normally get this problem.
whats the fix ?
Steve
Move the picture frame off of the CPlane so it is under where you are drawing.
Thats the only way, but then it disappears behind another I have moved, it also sees a surface starting to poke through etc, gets tricky when there are PictureFrames all 0.1mm or so apart. I wish they had a draw order.
Steve
