Dimension across details
Hi everyone,
I’d like to share a couple of feature requests and report a minor bug:
1. Dimensioning real model distance across split viewports in Layout Would it be possible to implement a dimensioning tool/command that can measure the actual model distance of a part split across two separate detail views in layout space?
F.E.: A long part doesn’t fit on the layout sheet at the desired scale, so I create two viewports showing just the start and end of the part. I need to place an overall length dimension spanning across these two viewports that reflects the actual model distance (ideally with a broken/jogged dimension line). (I’m aware I can manually measure the distance in Model Space and override the dimension text in Layout, but an automated command would be a huge quality-of-life improvement).
2. Native Arc Length Dimension (AutoCAD-style) Is there any chance of implementing a proper Arc Length Dimension similar to AutoCAD’s native style? Currently, the only workaround seems to be referencing the polyline length via a leader/text.
3. Bug report: Text orientation on sharp Angular Dimensions I’ve encountered an issue where the text orientation gets inverted/corrupted on certain angular dimensions. This mostly happens with acute angles oriented upwards (please see the attached screenshot).
Hi Dušan -
→ RH-27536 Wish: A way to make details of long objects
→ RH-2250 Arc/Curve length dimension
I’m afraid I can’t tell from that image what’s wrong here.
