DigitalArchi Compute Ecosystem - Project
Three associated Grasshopper plug-ins are part of the [DigitalArchi Compute Ecosystem] project introduced in the attached link:(DAC-Conpute-WebApp HUB | Food4Rhino).
These plug-ins are available through the Package Manager of Rhino 8 and form core components of DAC-Compute (DA Compiler-Compute).
DAC-Compute functions as an integrated Grasshopper pipeline architecture that compiles native 3DM geometric data into G-code, creating a direct bridge between parametric design and digital fabrication workflows.
The system is built on a high-performance geometric computation architecture developed for the DigitalArchi framework and incorporates several key capabilities:
Executing heavy geometric computations or varying input parameters won’t cause slow or frozen Grasshopper UI keeping the GH-Rhino interface smooth and responsive even during high-resolution calculations.
①DigitalArchiToolPath + ②GCode_Accelerator
This package includes three Boolean cutter (Brep) and toolpath-constructor (closed polycurves) , two Quality Control (QC) filtering components, and four G-code accelerator components, each implementing different optimization algorithms to improve toolpath generation performance and efficiency.
Main components (simple with few components)
SanitizePro Overhang Analysis Results
G-Code Generator (Printer-Based Flexible) Pipeline
For ③Data_Streaming_Bridge details, please refer to DigitalArchi Compute Ecosystem - link
