DigitalArchi Compute WebApps Hub
1. Introduction
The DigitalArchi Compute WebApps Hub is a cloud-based platform that enables users to compile Grasshopper, Python, and C# scripts—individually or in combination— into standalone web applications. These applications allow users to analyze complex Grasshopper geometry definitions directly within a standard web browser. Each web application connects to the user’s local Rhino–Grasshopper canvas, enabling direct interaction with 3D models and associated data (real-time data streaming)..
By running all computations on a secure dedicated cloud infrastructure, the platform eliminates the need for locally installed design-specific scripts or high-performance hardware. Users can enjoy non-frozen Grasshopper UI while having access to powerful computational workflows anytime, anywhere, through a simple web interface.
2. Interface Overview
When users access the Hub, they are presented with the main dashboard. The interface is organized into three primary sections:
  1. Sidebar (Left): Provides a navigation menu for switching between User Mode and Developer Mode.
  2. Main Panel (Center): Displays input configuration options and visualizes 3D results
  3. Input Tabs: Allow users to select how data is provided, including File, Text, or Live Streaming Link inputs.
3. Run a Simulation (User Mode)
Step 1: Select a Tool
  1. Ensure " Run Tool (User)" is selected in the sidebar.
Use the dropdown menu to choose the specific Grasshopper definition you want to run (e.g., Toolpath_Generator).
Step 2: Choose Permitted Tool(s) and Input Method
You have access only to the tools for which an administrator has granted permission. These tools are displayed in a dropdown list.
You can provide input parameters (DA-JSON data) in three ways using the radio buttons:
Option A: File Upload (Manual)
Best for standard users who have a pre-saved JSON parameter file.
  1. Select " File Upload".
  2. Drag and drop your .json file into the box.
Look for the status message: “Using Uploaded File”.
Option B: Direct Paste (Quick Test)
Best for quick debugging or small edits.
  1. Select “Direct Paste”.
  2. Copy your JSON text and paste it into the text area.
  3. Look for the status message: “Using Pasted Text”.
1- Live data streaming from GH canvas, sending input parameters to the server
2- Select Live Input option (A) , type the memory-ID (B), hit Check the data
3- After confirming data (if you wish) click Run Computation
Step 3: Run & Visualize
  1. Click the blue " Run Computation" button.
  2. Wait for the " Computation Complete" status.
  3. View the interactive 3D model in the browser window.
(Optional) Download the resulting .3dm or .json files from the Downloads section.
** Users can instantly modify input data—either partially within the editor or by uploading entirely new datasets—and re-run the computation. The system’s memory management optimizes performance, enabling accelerated processing and near-instant updates to the results.
4. Developer Mode (Admin Only)
This section is for administrators who want to publish new tools to the Hub.
  1. In the Sidebar, select :hammer_and_wrench: Developer Hub (Admin)”.
  2. Upload: Drag your Grasshopper definition file (.gh or .ghx).
  3. Name: Give it a clean, recognizable name (e.g., Paneling_System).
  4. Click “Publish to Hub”.
  5. The tool is now instantly available to all users
** Technical Notes: Setting up the Live Link**
The Live Link connects your local Grasshopper directly to the Cloud Server.
Architecture
  • Grasshopper: Sends data silently to db/upload/…
  • Web App: Reads that data instantly from the server’s data bank.
Grasshopper Setup
To use the Live Link, you must use the official DigitalArchi Gate Template Sender Component in your Grasshopper definition.
This is cool, I guess. Very little information though. Can we test this somewhere? Do you have a website?
Appreciate it! While our main business—and therefore our website—focuses on large-scale 3D printing and design capabilities, I’ll be sharing more information soon about the software we’ve developed to support our services and products, along with access to a test environment.
@seltzdesign I regularly share updates and ongoing progress related to the system’s technical aspects in this discussion: Build Cloud Grasshopper Apps via Rhino-Compute.
