Hi.
I need your help!
I have a cover full of pyramids that do not have the same dimensions. And I have to manufacture it. I had planned to do it in laser cutting, generate strips and thus optimize its manufacturing process. But I do not know how to do it. If someone can give me a guide on how to do it, I would really appreciate it. I am new to this topic and I do not know how I could do it. I share the definition
Fabricacion_Digital.gh (17.2 KB)
what do the details look like? Joints, Returns and such.
It is a metal structure. But how manufacturing should be a scale model. I just have to make the surface.
how would the scale model work?cutting, bending wise?
that is the doubt. I do not know how to achieve its assembly
To manufacture is a long journey, for my own problem I have developped a full range of tools (script, library …) and I mainly use Elefront as complement to Grasshopper. The main problem with metal is you have to take into account thickness, curvature of the bending …
If you want “fast” solution with paper or very thin you must use IVY,
Thank you! … I’m going to try that add-on
