Diamond Paneling Overlap Problem
Hello all,
I’m trying to generate a diamond paneling of various sizes (that will then get extruded and mapped on a polysurface). I need to prevent the panels from overlapping. Though when I try to use the Solid Difference node in GH, since my shapes are exactly the same sizes, they merge together instead of subtracting…
Anyone know a workaround this?
Thanks in advance!
– ea
Final result (but currently overlapping):
Example of diamond panels to subtract:
Failed Solid Difference result (they merged):
diamond-paneling_various-sizes_overlapping-issue.gh (32.6 KB)
Check this and you don’t have to use Surface Split all the time. try Isotrim.
diamond-paneling_various-sizes_overlapping-issue_re.gh (39.3 KB)
Big thanks for the quick reply @HS_Kim. Works perfectly. Didn’t know Isotrim, looking into that as well.
