Diamond Facet Surfaces
I want to create the faceted surfaces shown in the image onto the cylindrical surface next to it. I don’t know Grasshopper very well; how can I do this? I plan to apply the facets to the cylinder and wrap them around it using the “Flow Along Surface” command.
3. Attach minimal versions of all the relevant files
This might not be necessary. You can quad-mesh your cylinder (make sure it’s uncapped), then diagonalize the quad mesh.
Thank you, I will try it and share the result with you.Thank you, I will try it and share the result with you.
sample facet.gh (9.4 KB)
sample facet.3dm (74.6 KB)
Thanks for your reply, but I couldn’t quite draw it; how can I make the flat surfaces here more distinct?
How can I create flatter surfaces?
@René_Corella
sample facet lunchbox.gh (7.4 KB)
I tried doing this with a tiered lunchbox, but I couldn’t keep it up
What is being used in the video? I want to do exactly what is shown in the video.
sample facet a.gh (26.0 KB)
Thank you very much; I will try it right away. Many thanks for your time and assistance.
@leopoldomonzani
How can I add the diamond surfaces here to the pink surface?
sample facet b.gh (14.9 KB)
sample facet b.3dm (149.4 KB)
@leopoldomonzani
If you want to keep the faces planar I don’t know how to do it.
lunchbox.3dm (61.9 KB)
lunchbox.gh (7.8 KB)
I am creating surface panels (facets) using Lunchbox, but the surfaces do not remain flat; how can I turn them into flat-surfaced panels?
That is a geometric impossibility. The best you can do is have flat triangles, not quads.
I am trying to work within a triangular arrangement, but things aren’t going the way I want.
I want to create surfaces (facets) similar to the ones in the picture on a pipe.
I aim to divide the outer surface into clean, flat triangular facets with sharp edges.
My goal is to create the pattern while the pipe is still in its flat (unrolled) state—if possible—and then wrap it around the cylinder using FlowAlongSrf or another suitable method.
I need the triangular pattern to repeat symmetrically around the circumference so that the starting and ending edges join seamlessly when the pipe is closed.
Can anyone suggest a Grasshopper workflow for this?
Go Ali, go go go!
This might help :
Facet-Surface-Voronoi.gh (19.7 KB)
I gotta ask: why are you insisting on flat surfaces?
This does not have flat surfaces:
Neither does this:
What are you doing that require the surfaces to be flat?
You are right. I may have used the term “flat surfaces” incorrectly.
What I do not want is a raised pyramid or diamond relief, where each diamond has a center peak and rises outward from the tube.
What I am trying to achieve is closer to the reference image: a cylindrical tube that keeps its round overall shape, with a repeating triangular faceted pattern following the curvature of the cylinder.
The triangular divisions should create a sharp faceted appearance through edges and changes in surface direction, but without separate raised pyramids or deep protrusions.
So my goal is not a perfectly planar polyhedral tube. I want a round tube with a controlled triangular faceted surface, similar to the reference.
