Hi.
Pascal…MatchObjectLayer says unknown command in V5
Wim…
Excuse me?
I find that a rather worrying statement…
I dont understand your reply here and sorry if I caused some kind of offence…you had said
It just now dawns on me that you want 3 different types of
’identifiers’. One is the check mark in the Current column (with bold
typeface in the Name column),
I simply dont recall asking for anything to do with the check mark, I really dont.
I dont know how else to say that the check mark doesnt feature in my request, I looked through my posts but dont see mention of it anywhere.
How should I have said that ?..
BrianM
Personally I’d hate to have the layer list jumping all around and definitely don’t need the feature described
Ok I’ll drop that idea.
I’ll also drop the idea of it requiring expansion of trees.
I’ll drop any idea that causes any performance hit.
I will start taking notes on why I reach for such a ‘selected object sees layer indicator appear’
I shall then list them, if there is an alternative tool for each reason then I shall go with that.
Bear with me whilst I see what all my reasons are. I know a few now but its best if I list them all.
If I have twenty different uses for my request, having one fix is easier than having to remember a different fix method for each one.
Quicker to have one screwdriver with twenty different heads for twenty different screws I am working with than twenty different tools in a bag buried amongst a load of other tools.
I wish my projects were simple like the layer palette shown. Its the nature of my subject that it requires many many layers, 20x what was shown there.
Layers for:-
raster plans, I may have 30 in a project, each has a layer with its file name and to enable me to turn it on and off, or have more than one on, and have them translucent.
Aircraft sub type datums.
Station lines
Annotation dots
Contributed work has these but coming on on autocad named layers and I wish to keep these separate from my work.
different aircraft models datums, one layer per sub type.
cutting objects, 1 or 2 layers
sweep rails and profiles
construction lines
Dimension location lines
surfaces (1 or 2 layers, 1 for lofted, 1 for sweep, should I later decide on which one is better for my needs)
Dimensions from different plans, I need to be able to turn each set on or off, so each has its own layer and shade of green.
points and lines from photogrammetry. one layer per import.
sub layers for different parts of this as to have 160 points all showing is a mess !
surface through Photogrammetry points
different objects each have different layers.( each frame, each different structure, )
Surfaces kept separate to curves that created them.
Custom Cplane creation surfaces, each has a layer.
Object centrelines
Object points (aerofoil sections are first drawn with points, I need to have these off when aerofoil visible.
Annotation text and leaders.
I use layers to give colour to objects to help find them in the layers palette quickly.
I import a drawing from an autocad friend and he has allocated colours not visible in the layers. He will have several different coloured objects all on one layer. I have to select each object, go to properties, find the name of the layer, then find it in my layer palette, takes ages. I can look at my drawing and if its a purple longeron, look for longeron layer coloured purple. I do this either because I want to select his objects of that type and change their colour, or to turn them off or to clone them or to work with them in some way. No good using selCol as he has others I dont want also in the same colour. He uses just three or four colours for the entire subject.
His skins and objects separate layers.
I have sub layers set up so that e.g. all tail skins and their sweep rails and profiles sit in a layer called tail.
I have an area of the palette marked out with a dead layer dividers, #######subtype M below here ####### where all layers for a certain subtype sit between two of these.
If I need certain lines to stand out for client screen share or printouts I need to alter line thickness so they need their own layer. Yes I could alter line thickness by using properties but then I would have to be sure I have all these objects selected, else selecting one only sees that one curve go thicker in lineweight, if they are on a layer i simply alter layer lineweight and they all go thicker as required.
It is all very ordered.
Steve
