(7.7.21138.11001, 2021-05-18)
Packages are up to date.
Denoise doesn’t work (while it did in former versions).
See here:
See here:
Hi @Charles,
Strange. First of all, I’d like you to try this:
Will it now denoise?
Second thing to try:
%APPDATA%\McNeel\Rhinoceros\packages\7.0\
Does it work now?
-David
Both tries no success.
Same.
David, any news on this?
Version 7 SR7
(7.7.21151.13001, 2021-05-31)
Still no luck.
I don’t know what the problem could be. I’m also currently busy with other things, so it will take some time until I can get back to investigating this.
Have you tried deleting/backing up Rhino’s %APPDATA% settings folder? If I remember correctly it’s something like: %APPDATA%\McNeel\Rhinoceros\7\
. When the folder is removed, Rhino will generate a new one with fresh settings.
-David
Deleted the settings folder - no luck, still no result from denoise seen in the viewport.
Hmm.
Still no viewport denoise in
Version 7 SR8
(7.8.21160.5001, 2021-06-09)
Any progress on restoring the functionality?
Just installed Intel Denoiser and am trying to use it in Raytraced mode. Set sample count to 30 and my scene looks melted or like it’s been sprayed with fireproofing. A lot of elements in the scene (beams… stairs) have lost their straight edges. Has there been any progress on this?
Can you post your system info? (command line SystemInfo)
Which denoiser are you using?? *intel
That was fast! My denoiser is IntelDenoiser v0.6.4.
And my System Info is–
Rhino 7 SR13 2021-12-14 (Rhino 7, 7.13.21348.13001, Git hash:master @ 7696723f74a63695b3c372a89110c0ca8c78b890)
License type: Commercial, build 2021-12-14
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P2000 (NVidia) Memory: 5GB, Driver date: 12-6-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.84
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-6-2021
Driver Version: 30.0.14.7284
Z-Buffer depth: 24 bits
Total Video Memory: 5 GB
C:\Users\Cosmas Demetriou\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.4\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.6.4.0
C:\Users\Cosmas Demetriou\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino WIP\Plug-ins\Commands.rhp “Commands” 7.13.21348.13001
C:\Program Files\Rhino WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino WIP\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino WIP\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.13.21348.13001
C:\Program Files\Rhino WIP\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.13.21348.13001
C:\Program Files\Rhino WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.13.21348.13001
C:\Program Files\Rhino WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.13.21348.13001
C:\Program Files\Rhino WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino WIP\Plug-ins\Displacement.rhp “Displacement”
Hey Cosmas… try a few more samples (like 200) and make sure the intel denoiser is the one that is working…
the nvidia will only work with rtx cards (to the best of my knowledge) so you may want to uninstall it.
Thank you!
