Hi, i have a problem. I can not delete edge on surface. I tried splitface to merge later two faces together but it faild. i tried “Split surface by isocurve” but nothing was happend. how to delete edge on surface?
i have a issue when i try to fillet surface. One face is not deleting itself and it covers the fillet
Please try to use DupEdge to extract three 3 edges showing as blow, then use these curves to split the area you mentioned earlier
For your current case, please try to run MergeAllCoplanarFaces before you run FilletEdge command.
Thanks Jessesn. It works. ![]()
