When I select a layer that I want to delete in the layers panel, the delete key will not work. I need to click on the Delete button at the top of the panel.
This is a small glitch but it does effect the workflow.
Will this be fixed?
Dana
Hi Dana -
It is a nuisance not having it.
Hi Dana,
Like
that -wim mentioned above ![]()
Hi Dana -
From Rhino 7.6 on Windows, the default behavior will be that you can delete layers with the keyboard delete key again. To turn this behavior OFF, uncheck the advanced setting Rhino.Options.General.EnableLayersPanelDeleteKey.
Also see: RH-63265
