Hello!
Test-driving Rhino 6 WIP, and noticed that the Delete command is simply not working! Neither by pressing DEL, nor by entering the command.
I’m not on a locked layer, and it does not work on any object.
Cut (CTRL-X), however, works.
The scene I noticed this was originally created in Rhino 5. So I just started with a fresh scene, with just a few lines - no, delete is broken (Cut works). History is turned off.
Rhino version: 6.0.17031.12411, 31.01.2017
Hello! Thanks!
ESC key works fine… Deleting components works, too.
In this second I found the cause:
there’s this (new?) mode, when objects are selected, their points are displayed automatically without having turned on ‘point display’.
It’s called “Turn on control points when selecting a curve”, under Options > Mouse.
In that case, the object cannot be deleted! Makes sense actually…
Duh…
Sorry for the noise!
Best
Eugen
… which rises the question: if I actually like and want to use that mode - is there any modifier key combination / toggle to then select an object normally (without turning on the points)? Does not seem to be.
However, not sure if it makes sense to do it that way - putting that macro in a button or alias - since then I could as well just toggle the object’s points on, which goes against the whole idea of this new option.
Hi All - there are two settings under Options > Mouse - one turns on points on selection, and one allows object selection with points on- the second one is the one that needs to be enabled to make Delete work.
