Hi there. I have a polysurface on which I use the “flow along surface” command, but unfortunately it get deformed in an unexpected way. The dimension of the objects are really changed, as you can see I had a set of 2.46 holes, and end up with holes varying from 2.4 to 2.54:
Oh great, I could not find it. Many thanks. So by using the UnrollSrfUV command and then using it as a base surface of the FlowAlongCrv while keeping AutoAdjust=No worked! (and issue was due to NURBS stretching)
Hello - if your target surface is not developable, it can help to make a copy of the target surface and Rebuild to a very dense point count - this will even out the UV - and use that as the target, and just delete it when done.
Hello @pascal , I am sorry to disturb , but I am again in a similar problem so I thought I could write in this post.
I have a polysurface that I created by using the “sweep 2 rails” command, and now I can’t use the last solution (UnrollsSrfUV) to have my curves on this polysurface. I tried to project curves, to create a surface instead of a polysurface but nothing wokred so far. Is it possible to somehow project flat curves onto a polysurface without deformation?
