Hi there, I’m currently using the most recent build from 2014-05-20 and it seems that the default template has been changed from using mm to cm… is this so? Every time I create a new model (cmd+n) it now defaults to using cm instead of mm like it has always done in the past.
If I go to the menu and select New From Template it shows me all the templates and has “Large Objects - Centimetres” at the top and listed as being the “default template”.
Is there a way to set the default template file back to “Large Objects - millimetres” (or any other sized object for that matter) but in mm instead of cm?
