Hi.
I’d like to separate UV coordinates of a point (on a surface) into single values. Kinda like “Deconstruct Point” does into xyz-coordinates. How can I achieve that?
Thanks in advance
Hi.
Thanks in advance
IIRC, you can just use a normal “Deconstruct Point” component. The X output will be U, the Y will be V and the Z will be 0…
–Mitch
Brilliant! Thanks. But not very evident I must say.
Grasshopper 1 does not distinguish between XYZ and UV points. Grasshopper 2 may, not sure yet.
