How to convert x,y,z coordinated to UV valuess
Hi I’m new to this so let me know if this is not the right spot.
How do I convert world x and y coordinates into the U and V values of a surface? I currently have a list of points with their x and y values extracted and i wanted to know what was the corresponding z values of the points on the surface. I was wondering if I could use the evaluate surface component but that needs UV values not world coordinates.
If you’re working with Grasshopper, it is the right spot :smile:
What is also possible is to create lines from the (x,y) points in the (0,0,1) direction that intersect your surface. Then find the points of intersection and their Z-coordinate.
Project Point may be of use here.
The [Surface Closest Point] component returns the UV coordinates.
THANKYOU!! That was exactly what I was looking for :smile:
