Decals in rhino 7
Decals works only in Raytrace mode (Cycle)
I can`t see decals in any other mode
Wersja 7 SR10
(7.10.21256.17001, 2021-09-13)
please run systeminfo in rhino and paste the result here-
do they show in rendered mode? they should only show in rendered or raytrace mode by default.
You can change the display material in shaded mode to rendering material.
I changed the display material in Shaded mode to “rendering material” without any result
In Rendered mode this option is inactive, but option "rendering material " is shown
Decals appears only in Reytraced mode
Below the system info:
Rhino 7 SR10 2021-9-13 (Rhino 7, 7.10.21256.17001, Git hash:master @ 68677dc86520a0de9485d8b8fa2e841e757733f3)
License type: Komercyjna, build 2021-09-13
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: LAPTOP - Plugged in [95% battery remaining]
Primary display: Intel(R) HD Graphics 530 (Intel) Memory: 1GB, Driver date: 10-14-2020 (M-D-Y).
Primary OpenGL: NVIDIA Quadro M4000M (NVidia) Memory: 4GB, Driver date: 8-5-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 471.68
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 3.3
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-5-2021
Driver Version: 30.0.14.7168
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\Marek Suchowiak\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\AMDDenoiser\0.5.2\AMDDenoiser.Windows.rhp “AMDDenoiser.Windows” 0.5.2.0
C:\Users\Marek Suchowiak\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.3\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.6.3.0
C:\Users\Marek Suchowiak\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.1\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.1.0
C:\Users\Marek Suchowiak\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\rhinopbrmaterial\1.1.4+v6.16\RhinoPbrMaterial.rhp “RhinoPbrMaterial” 1.1.2.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.10.21256.17001
Don’t use this material in Rhino 7. Instead use the Physically Based Material that is provided by Rhino itself.
Also, make sure Rhino Render is set to be as the current renderer.
The object am using in rhino7 has only simple color (not pbr material)
The problem of decals is based probably on configuration of this computer or relation betwen rhino and my hardware - on the different computer where i am using rhino7 this problem doesn exist. The decals appears corecty on each defined modes.
On this computer I cannot see the decals on any modes exept reytrace
