Hi
I need help about the decal for object copied Infact if I assign a decal to an object e I copy it I cannot change the decal If I change the decal in one of them automatically it changes the decal to the other
There is a way to avoid it?
Regards
Viviana
Hi Viviana - if you need a different decal on the copied object, you can delete the current decal on that object and then apply a new one to that object. Does that do it?
Dear Wim
Yes It works but in my opinion it would be easier to change the picture and unlink it to the original object
Regards
Viviana
Hi - I’m afraid I’m not understanding the workflow here. Could you explain in more detail how you are changing the picture on a copy of an object with a decal?
I’m afraid not.
You write:
I copied the tapes and tried to change the labels
How do you try to change the label?
Could you please post that file?
Here you are the file and the pictures
display_1-8_maskspec.3dm (5.0 MB)
Dear Wim
About the decal inside the tapes I’ve just realised that it doesn’t render if you set from 0 to 360 degree It works with 0,1 to 360
Regards
Viviana
Have you solved this problem? I am looking for answer also
Ran into this problem even now. I believe what we want is simply the ability to “create unique decal” like we have “create unique texture”. The decal is shared between all copies. I want to select let´s say a third and asign them different decal. Is this hard to implement?
