Edward
(Edward)
April 10, 2018, 10:32pm
#1
I have problems with making a complex part wherein galapagos picks surface to a minimum surface with enough daylight.
I have two questions:
Honeybee and galapagos is the best way to optimize floorforms and windowforms to get a minimum surface and enough daylight?
How can I make a selection system (complex part ) wherein galapagos can sweep on a number slider?
About question two, I tried to combine texts and try to find out how selecting branch work. However, it went not that well…
Daylight optimization galapagos basic model 01.gh (12.0 KB)
tim.stark
(Tim Stark)
April 11, 2018, 11:55am
#2
Ladybug/Honeybee and Octopus. Octopus cause you want to optimize 2 goals. Min area and max daylight.
Here you got simple “list options”. You could also Combine them etc.:
I don’t clearly understand how it should look in the end, but that’s what I understood:
Cull pattern, cause it’s no Problem, if you cull the same index twice. So no dupl items etc. Amount of sliders in the genepool are the amount of panels
