Hello, I have a problem with trees. I have some surfaces grouped into 4 branches - each branch marks one of edges of a rectangle where surfaces start. Structure is {x;y} where x is index of curve and y is edge of a rectangle.
I know the description is messy, but heres a definition:
TREES_PROBLEM.gh (29.6 KB)
What i want to do is take each edge of each surface in each branch and “project” (in z axis) it to all other surfaces in THAT BRANCH, and split each surface afterwards. I thought of numerous ways but what i ended up doing was:
- get each surface edges
- project all curves to xy plane
- extrude lines
- find intersection between initial surfaces and extrusions.
The thing is number of items in corresponding branches are not equal between initial surfaces and extruded lines. I grafted the extrusions. As far as i understand a structure of:
{x;y} for surfaces and {x;y;z} for extrusions should create corresponding intersections - so all intersections for each surface in {x;y} with a corresponding z. In the meantime I get strange results.
I’d appreciate any help.
Thanks, have a good one.
