As you see the pics, I have two sets, each set has one curve and a point group (four points). I want to use two “Geometry” in grasshopper to choose each sets, then finally get a tree as I indicte.
I tried but it’s a mess. First, I don’t know how to seperate curve and points in “Geometry”. Second, the eight points will be one group.
Thank you all!
That code is written with the intent of handling an arbitrary number of circles with differing numbers of points in each one. But it contains an error that I didn’t notice until I built a proper “test jig”, below:
If I had an hour to solve a problem and my life depended on the solution, I would spend the first 55 minutes determining the proper question to ask, for once I know the proper question, I could solve the problem in less than five minutes.
That’s a great work! Thank you so much, Joseph!!
It’s really what I want to do in the next step.
And thank you for your suggestion on how a questions should be proposed.
I am so luck to have helps and supports from kind guys like you!
