Anemone end loop component wait until the current solution completed (aka all component expired are fully re-calculated), then it will trigger another cycle of the loop, over and over.
Data Dam component does not expire anything, so Anemone will not wait for you to press the play button on it. Wrong premise.
If you can explain what you are trying to do, maybe we can find another solution.
I dont have a Data Dam component in the Anemone Loop - so I’m not sure why you and Joseph have mentioned this?
I can get Anemone to have a control over its loop speed when I just build a little example on a clean GH, but copy the same code in to my main program (not even connected to anything) and the Anemone Loop runs as fast a possible - not waiting at all for the data inputs.
The first example I was using the data dam with a 500ms delay to SIMULATE a much larger piece of code that takes time to complete. In particular a Kangaroo a based relaxation model.
I’ve had this system going for a while but just in the last few days noticed that the loop was pushing out 2/3/4 times as much data than the rest of the program was able to calculate. Now I can see that I need to slow the loop down, but it refuses to in my main canvas.
a Kangaroo solver inside anemone? Hopefully Zombie solver…
Still, we have no idea what you are doing and why you are doing this way, impossible to help properly, sorry.
If you expect few iterations, try to use entwine and explode tree component, and just use a couple of data dams with “never” time, and you manually cycle through iteration by pressing play buttons
Yes the zombie solver in K2, the code is actually something I’ve had in production for a while, I just went looking at a minor bug yesterday and actually found a whole rabbit hole on an issue.
This video show the behavior I would expect - first half of the video - with the Buffer keeping the loop to a 1 sec cycle and my ‘faux’ slow code being 0.25 and 0.5 sec to complete everything staying in sync.
Copy the code from the test file and drop it into my production code and WTF - it flys away at full speed - not even slightly slowing down for the Buffer component.
The Not gate wired to Loop End ‘E’ input is completely unnecessary and should be removed. Default for that input is ‘False’. It can be set ‘True’ by code in the loop to terminate the loop.
I’ve never seen or used the Buffer component before, yet written hundreds of Anemone loops over the years. Great plugin.
