I recentlyhave installed Vary 5 for Rhino, and have an issue with saved render images. I increase the exposure and what I see on the VFB is quite bright but it won’t save like that and all saved images are dark, appreciate any help to fix this.
What format did you use? it may be related to color profile? or wrong Gamma Settings. sharing your file (or portion of ) can be helpful for me to reproduce your issue.
Hey thanks for your reply, what do you mean by format? I think it is gamma setting but cannot find any options to adjust it on the render output
What file format are you saving it as? JPG? TIFF? EXR? It seems like either the gamma settings in your render aren’t getting applied to the saved render–which makes no sense?–or you’re saving it in some “HDR” format where it’s virtually never going to look exactly the same in some other program.
I am trying with png, jpeg, but it shows the same result. I am increasing the exposure, on previous versions, it exposure correction was applied on the saved image, but on this one it seems not.
just saving in png, jpeg, no other format. color profile is set as sRGB. I had the exact setting worked on a lower version of Vray, but i updated today and it doesn’t save the exposure correction.
did you try it on another rhino model?
yes, I did try it on different models, and it is the same
will test it now and let you know, thanks
yes, it is working now, thank you so much. I just wonder why on previous vesions it would have saved the display only exposure correction, but not on Vray 5, was it a deliberate change?
I think so, It was a major update when it comes to VFB
Thanks for your help!
