Do you know if is there any way to enable/disable shadow in raytraced mode by code?
Thanks and best regards
Apparently DisplayPipelineAttributes isn’t completely wrapping all possible settings. Casting of shadows is not available, and some others are missing too. I have logged RH-44100 for this.
Note btw that you still see shadow generated by skylight, even though shadows are turned off. It is on my list to fix (RH-38107).
Access to DisplayPipelineAttributes for Raytraced: use RaytracedId as argument for GetDisplayMode, then use DisplayAttributes on the DisplayModeDescription to get the DisplayPipelineAttributes
/Nathan
Ok Nathan, Thank you for let me know it!
Best Regards
Enric
