Cut Pattern (Section Style) Not Displaying Correctly on Rhino 8
Hi, I am having trouble with the cut fill pattern on certain objects where it displays momentarily and then disappears leaving the solid appearing like an empty shell which you can see into. All the obejcts are solid polysurfaces that have been capped and i have tried a variety of different types of cut hatching on them and the problem persists. On the video you will notice other objects with the same cut fill settings displaying normally.
What am I doing wrong?
Hi Seychellian,
Please post your SystemInfo and a small example file (if possible), thanks
https://discourse.mcneel.com/t/please-read-this-if-you-are-logging-a-bug-or-issue/173971/3
Hatch Issue.3dm (18.0 MB)
Thanks, Please run the SystemInfo in the Rhino command line and post the results.
Rhino 8 SR8 2024-5-14 (Rhino 8, 8.8.24135.14001, Git hash:master @ 8c191427bc5c6c4e62f523a752d809f68897c3a5)
License type: Commercial, build 2024-05-14
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 980 Ti (NVidia) Memory: 6GB, Driver date: 5-13-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.85
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-13-2024
Driver Version: 32.0.15.5585
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 4.1.0.1388
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.2.0.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.8.24135.14001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.8.24135.14001
Thanks for reporting RH-82726, I’m seeing some issues as well. Going to do some more testing to try an narrow it down before i file a youtrack. I’ll post it here when i do.
Thanks
Any leads?
Any updates will be noted on the youtrack. The will first be in the Service Releases Candidate which come out late Tuesday, early Wednesday typically.
Sorry but what is “the youtrack”?
Youtrack is the bug reporting system that we use.
