Clipping plane section style not showing
Hi all,
My clipping plane section style is not working properly. The hatch pattern doesn’t show and I have tried changing it through “by layer” and it does not work in all my display modes. The old-fashioned “show fill with solid color” works fine tho. I updated to R8.12 but no luck.
Does anyone has the same issue?
Thanks
clipping plane issue.3dm (6.3 MB)
You’ll need to set the boxes section style to “By Clipping Plane” if you want it to use the section style of the clipping plane. When objects get created they default to “By Layer” for their default section style info.
Thank you @Trav!
