Hi! I’m pretty new to Rhino and Ghp and I was doing a pavilion where the walls are based by a Mobius Strip, and I was wondering if anyone knew how can I boolean this intersection so my wall will cut where it intersects with the red volume? Thanks in advance.
Hi Rodrigo -
Since you included Boolean tags in your topic - those operations rely on the normals of the objects involved. A Möbius strip is a good example of an object that will cause issues. You’d have to create a version with wall thickness for this to work.
With the objects as they are now, you could create a horizontal plane at the required elevation and use that to Trim the wall.
