Customise Colours
Hi
Just a quick post with an idea…
The ability to create a list of display colours and rename the colour(s).
I know you can sort of do this using Rendering colours but would be so useful in the display pallette.
Also have preset folder/layer names. I frequently name folders using the same names. Would be great to have a list containing all the common names. Pushing the boat those names have preset colours.
ib
Hi Ian - you can do this, if I undestand you, in a sort of roundabout way by editing colors.txt here:
“C:\Users\USER_NAME\AppData\Roaming\McNeel\Rhinoceros\7.0\Localization\en-US\Support\colors.txt”
That will control the list that shows up in the color picker:
Hi Ian -
As for this one:
In a new file, set up the layers that you want, with the colors that you like. Save the file as a template and start new projects from that template. You can also import that template file into existing projects.
Hi Wim
Thanks for suggesting the idea. I used to do that but quite often I purge the file losing empty files.
Hi Pascal
Very interesting.
Its probably the nearest to what I’ve been looking for.
Thank you
