Custom colour
Is it possible to create a custom colour? I mean, I would like to have a “named” colour, or even my own palette of colours, and I would like to change the properties of such element. I use quite a lot of elements (the Visual ARQ elements) and their properties are set “by level”. Then, when I want to change the colour of a level I have to change properties of all elements… With the named colour it would be enough to change properties of the colour, ie. its HSV or RGB values.
I use the Rhino 5…
Regards, Jaro
Hi Jerry - see if this is what you’re after:
https://docs.mcneel.com/rhino/6/help/en-us/index.htm#user_interface/select_color.htm?Highlight=Colors.txt
Fantastic, it works! Thank you very much, Pascal!
Cheers, Jaro
