Custom nudge settings for UV editor
Hi McNeel
Now that the UV editor no longer resides in the realm of the WCS, would it be possible to have a custom set of nudge settings for the UV window? I can easily script a set of custom settings for the UV editor and for model space, but switching back and forth gets tedious real quick. I have 0.1mm, 0.5mm and 1.0mm as my nudge settings and in the UV editor that’s way to coarse.
TIA, Jakob
Logged as RH-80028 Custom nudge settings for UV editor
I hope it’s okay if I describe my problem directly here before I open a new topic.
I can’t use the command UVN-Move (Set nudge UVN).
When I want to use the command, the following happens:
Command:_NoEcho
What is the cause?
Rhino Version: 8 SR6 (8.6.24101.5001, 2024-04-10)
