Can't set scale value in Move UVN
Hey
When I use the Move UVN tool I can’t set a lower value than 1.
It doesn’t allow me to put a dot in the text box. Any one else have
a problem with this. Or is it some setting I should change? Couldn’t
find any info on it.
Thanks
Sorry for the delayed reply.
I’m having following this. Do you mean you can’t set the Scale value lower than 1?
Can you provide a file or complete steps to reproduce what you are seeing?
Yes exactly, I can’t set the value lower than 1. It’s not related to a file. It is the same for every
file I work with. I am not sure which steps you want me to describe. It’s just that as I try to put in a value of example 0.8
it won’t accept the dot (.) and just puts in 08. This makes it disregard the 0 and just treats it as scale 8. Comma (,) doesn’t work either.
What version do you use? It works with the latest version: http://www.rhino3d.com/download/rhino-for-mac/5/latest
https://docs.mcneel.com/rhino/5/help/en-us/commands/moveuvn.htm
I use 5.2.2. Is it something they updated for that version?
