Hi!
we are developing a plugin with custom grips and the users would like to have the gumball align to the object when using these grips. Is there a way to do so? We searched the docs and samples but we cannot find any solution for this
I am not aware of a direct solution, but some possible options are:
Using CustomGumballs (could be an alternative to the grips, I am not sure if they can be used side by side). There’s an example with a cylinder in the RhinoCommon docs. You’ll have to manually set up the transformations, picking and triggering on/off the Gumballs.
When your custom grips are selected, change the Gumball alignment of Rhino to ‘Object’ through command (RhinoApp.Runscript()), and change it back after grips are off.
unfortunately it does not help. I do not want to implement custom gumballs as the grip infrastructure serves my need almost 100%. And the runscript is not what I am trying to achieve.
The problem is that the gumball does not align to object even though I have it set to align to object.
