I have installed Rhino 6 Beta, and opened it successfully.
Unfortunately if I draw curves - they are all invisible.
But if I select an invisible curve, the selection is OK.
In the display panel - curves are checked.
Surfaces and Poly surfaces are well displayed.
Hi Rachelre
I had the same problem and it is OK after updating the display card driver to the latest edition. The curves are visible even with the GPU tessellation checked.
As Mitch says.
It’s recommended, though, to uninstall your current drivers before installing new ones - from the Windows Control Panel > Uninstall a Program.
Dunno, 15 years ago this was pretty much required, but today? Personally, I’m pretty lazy, I always just run the installer. Haven’t had any problems to date, but I guess you never know…
Hi Rachel - no problem really, I think, it’s just slower. But if you can get the drivers updated, that’s probably a good thing regardless, and it may fix the GPU Tessellation problem as well.
Yes I updated my drivers at Nvidia website, there are many other independent sites offering the drivers update but better to do it at Nvidia driver page. Nvidia does a scan check on your system to determine your card specs. So pretty straight forward, but then do back-up all your files. I did.
These days small updates in windows sometimes requires driver update… not sure if the installation corrupts the file or something…
Nvidia also updates drivers frequently so if anything goes wrong it’s worth it to check.
