Curved wall with curved top
I need to generate the below wall. I’d like to a) be able to do so from curves, and be able to b) adjust both the top and base arc once it’s modeled and c) adjust the slope on the top of the wall. Wondering how best to go about this.
Wall.3dm (4.7 MB)
like this?
Oops couldn’t open this R8 file thanks ERahjes. I should have listed my system as current Va2 on Current Rhino7 (for now).
Also I should mention that there will be specific curves the top and bottom of the wall need to conform to. The bottom curve will only arc in one plane. The top curve will be generated from a 3d object arcing vertically as well as in plan.
@djhg You can create the wall from a curve, and extend it to a sloped surface (with the vaWallExtend command), which is what you can see in ERahjes’s file.
The curve I will have to use for the top of the wall will likely not be all on one flat plane.
You should be able to use any surface you want for the top plane. Just extend the wall to the surface and then put the surface on a non-plot layer.
